Good deal. They make better filters for them. Oiled foam aftermarket.Gday,
that I am. Purchased a new Stihl 661 couple months back while on sale and I can’t believe I haven’t even checked the air filter after a few tanks… I know what will happen![]()
Thanks for the welcome…Definitely feel at home. It doesn’t end with chainsaws, RCs it extends to my Harley, boat, leaf blower kids toys and even the 1953 Massey Ferguson has a new Chinese turbo and Chinese copied Corolla carby sitting waiting to be boosted.Looks like we got another one.
Into saws , toy cars and not afraid to mess with stuff. You'll be right at home here.
and welcome if I missed that earlier.
and he has saws sitting on the shelf for 15-20 , heck he might even be in the same age group. LOL
If you wanna bs about hot rodding sass n other toys, maybe you, smokinwheel and myself need a PM lolLove it!
I'll fire one up...Anytime is good for me. You guys want to BS just let me know. I'm in.
What exact crankshaft did you end up using as a donaBolted the engine back together with the hybrid crankshaft ( DDM Zenoah stuffed crank cheeks , Original slotted and drilled con rod), lightly ported the cylinder and cleaned all casting flash out of ports : fitted new Akill lightned piston with port window .
Pasted all gaskets with Yamabond on build up.
Bolted to mt test stand and it fired right up on fourth pull .
Seems very smoothe and responsive.
Running a few tanks of fuel through it at the moment and tuning the carb.
Initial impressions are very good.
What exact piston did you end up using where did you purchase it wouldn't mind giving that goBolted the engine back together with the hybrid crankshaft ( DDM Zenoah stuffed crank cheeks , Original slotted and drilled con rod), lightly ported the cylinder and cleaned all casting flash out of ports : fitted new Akill lightned piston with port window .
11hp WowZers! Not with those stock ports! Lol. Wish we coulda seen it run stock so we can get an idea what kinda power it makes. Many don't have the ability to do what you did to it. Have to look up and see if there's anyHad the engine running on my test bed again today , seems very very nice runner and great starter. I think it is very well made out of the box , big bearings and slotted con rod , carbon reeds and so on : I only changed the crank and piston as I wanted stuffed crank for less crankcase volume , and piston because I wanted a port window in it . Ports just need a bit of clean up and knife edge , removed quite a bit for casting flash out of ports , but absolutely worth the price .
I know loads of people on here will hat it as it is not made in the USA , but I don`t care.
Not sure about 11 HP , but seems very clean running and crisp on take up . I have a 36 rovan , and it feels much more lively.
going to run it on my SC truck this spring , so will see how it goes.
What crank did you purchaseBlended edges to crankcase and slotted rod being fitted to stuffed crankshaft
