Primal raminator grave digger
Brooklynhalo
I upgraded it all to v4 standards new electronic box in the rear v4 harnest but the truck wont shot off when i hit the switch on channel 3 it works when it wants to random now i tested the signal on the kill switch and the physical kill switch with my tester and i get contenuaty and when i hit the 3rd channel it cuts the signal as it should my only thing left is the ignition coil or fly wheel any one with experience help me thanks
Radio...brake endpoints must be 85 % or less, mine is about 80 %. This is with primal factory flysky radio. Does. The actual red button/engine kill switch work properly and does the toggle switch work. If they are working OK then it's your brake servo endpoints for sure.
Yea the switch works when hit light toggles to green when press then to red when pressed again end points are set to defalt 100 on each direction i have not played with it some times works when it wants to ill try the new end points when i get home
the truck starts like it should but i cant shut it off i have to pinch the fuel line for it to shot off
So if you press the red kill switch on the engine it will shut off or flip the toggle switch on the frame the motor shuts off.If those are working correctly then l would say it's probably radio settings. Sometimes on these trucks full throttle kills motor too, again it's the endpoints. After adjustments to radio you can make mechanical adjustments to get full brake and throttle.
when the truck is turned on i cant shut it off from the controller or the toggle switch it stays on but im getting good reading from the kill switch and the toggle switch on my meter when testing
Hmmm....only other things coming to me are is the wiring from engine to toggle and frame correct. Your saying that the kill button on the engine will shut it off? Also is the electrical, black box, wired to 3rd channel on receiver. It's been a long time since l upgraded to v4 harness but l remember eliminating a spliter at the kill switch box . Don't forget also that no power comes from battery to ignition coil . The electrical kill switch is simply grounding the coil to the frame. Try your endpoints and go from there.
when the truck is turned on i cant shut it off from the controller or the toggle switch it stays on but im getting good reading from the kill switch and the toggle switch on my meter when testing the only way i can shut it off is to pinch the gas line untill it turns off i i matched up the wires the same as my other raminator so im stumped
So l forgot the stock raminator engine doesn't have a kill button on the engine like the zenhoa . The toggle switch is used instead. This is the y harnesses l eliminated l think. Did you reset the radio endpoints
yes i eliminated the y cable because of the v4 harnest i did reset the end points but the odd thing it i get spark to turn on the truck and when i run the truck sometimes the i can kill it from the 3rd channel it works when it wants to but less and less as time has passed im i tried a new coil and nothing
I wouldn't think the coil. Are the wires to toggle tight and correct. All the pins tight in receiver. I've never had a issue with the factory triton kill switches, even got one and flysky radio in my baja . Only problem l ever had was figuring out how to wire them properly to get my stuff to run.....which was usually just one wire in wrong spot. One more thought if you shut the radio off does kill switch work..... just don't leave it or servos burn up.....be careful. We may be just chasing a bad switch or it needs rebound or programming per primal manual
Ok mick I took it apart followed all wires from manual and my other raminator for reference put everything back together peace by peace all works well exept ehen I install the exaust pipe when exaust pipe is installed it causing a ground issue I took the exaust out it won't kill the engine
Wow that's unreal. Do you have the metal shield on plug wire, if so remove it. I'm pretty much baffled at this point.....any one else got any ideas.
