- Thread starter
- #41
Yeah, it's time to hop on the Lucas red n tacky train. I should have picked that up a long time ago.
Great update and good job.I got the transmission all cleaned up and applied the red n tacky. It is working flawlessly now. I notice a huge difference between the red and green.
Nice...3 minds solved an issue....amazing how that worked out....l still think the the rc community should govern the world....
The shafts should rotate opposite of each other.Before I start taking things apart... I got it all back together and realized that the rotation of the front tires opposed the rear. If I spin the rear driveshaft, the front driveshaft spins opposite... i could have sworn I put the diffs back in the axles the exact same way I took them out. I can't imagine the transmission would have went back together wrong, and I didn't think to check rotations before I took it all apart.
Thoughts?![]()
If i rotate the rear wheels forward, the front wheels go in reverse. If the driveshafts are supposed to spin opposing eachother, then i reckon I accidentally put in a diff backwards...The shafts should rotate opposite of each other.
Put 2 wheels on one side and rotate one wheel and the other wheel should rotate the same direction.
Then the driveshafts are both rotating the same direction … akin to a very long pencil; correct?If i rotate the rear wheels forward, the front wheels go in reverse. If the driveshafts are supposed to spin opposing eachother, then i reckon I accidentally put in a diff backwards...
No, the shaft is not suppose to spin akin to a long pencil.If i am looking at the side of the truck and rotate the rear driveshaft towards me, then the front driveshaft rotates away from me. So not like a long pencil.
I am pretty positive the diffs went back in the same they came out. I feel like it would have been hard to put those back in wrong. If the driveshafts are supposed to spin with eachother like a long pencil, then it looks like I need to take the transmission apart.
Your rear ring gear is on the wrong side of the pinionIf i stand at the driver side and rotate the rear driveshaft towards me, then the front hubs rotate counter-clockwise and the rear hubs rotate clockwise.
Thank you. I'll take that rear axle apart and check the diff.Your rear ring gear is on the wrong side of the pinion
Open the diff rotate the carrier and ring gear assembly 180 degrees and put it place… button it up and smile.Thank you. I'll take that rear axle apart and check the diff.
