Well I decided to go with a new head for my CY 26 and zen 23cc.
Right ,the model number on the CY is CY29398B.its a standard 26cc with no mods.I wrote to DDM today to ask advice and he put me in the direction of this
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.4835/.f
but i was thinking on the lines of this
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.4836/.f
The latter comes with a stuffed stroker .Will this stroker set up work on my engine?How can i tell if mine is a stroker crank set-up already? Its a bit confusing to say the least!
Here is a copy of the original email i sent.Can anyone shed some light on it.
Hiya,I've been doing a bit of searching on your site and need a bit of advice.I have a CY29398B 26cc engine that needs a head and piston upgrade.Would you recommend the CA486+dd321 or the CY billet head cc50x + dd3x and is it compatible? also I have another Zenoah 23cc standard engine that's a bit tired and was wondering if the CA481 was compatible as well? I need a crankcase gasket and the one I have chosen is yellow and not the standard blue that's on the original crankcase does it make any difference? I also need a carb spacer but cannot find it on your site.
Thanks in advance.
J.:blush:
Thanks in advance.
J.:blush:
