outerwares
Is that standard lycra Voo and what are the real ones made of?
Matt.
Just standard stuff mate.I don't have a clue what the real ones are made of but this one seemed to work 100%!
No Dwarfy,it was made out of Ians hot pants with bum cut out:blush:
Cant go into great detail I swore I wouldn't tell anyone!
J.
hi all ..
i thought the outerwears were waterproof but reading there site it says there only water resistant...as we had a 2 hour enduro race most cars still got mud crapy water thru there carby that were using outerwears..air filters...and most engines died out or just wrecked...
ambro
hi all ..
ambro
If they were water proof mate they would be air tight as well.No air for the mill.
J.
I think I need to get one for the pull start as well! Have been having over- heating problems where after about 10 mins run time the engine starts to die, and there is no fuel in the primer bowl, but when I run it without the body shell on its ok, I cut out the front and side windows but it didn't make any difference, hopefully with this lot dunged out it will be ok. The other problem I had was the clutch overheating with the higher gearing fitted so it was labouring at low speeds, the knock on to this was the grease in the bearings melted, I'm wondering if this is just another side effect of the engine overheating and transfering through to the clutch.
Cheers J, I didn't think of that, it didn't take long to get like this either! 2-3 tanks at most.
