mooman007uk
- Thread starter
- #21
so my pipe and motor arrived yesterday, pipe fits straight in just about perfect and will fit under the stock MT body with about 1/4 clearance...some foil tape will make sure it doesn't get too hot, I just have to turn a rear cage mount screw around to give 3mm clearance as it's the only tight spot...to mount it I'll be replacing the front cage crossbar with 4130 tube and take 2 struts forward to the shock mount...then weld a mount tab onto the tube and job done...going to try the pipe first with the 26 (though it's designed for modded motors) to see how it goes then throw the 27.2 in and see if anything gives out
