where do i start LOL
K, .... a serious question!!
There's been much discussion on this Forum recently regarding battery problems, considering the fairly substantial investment in the beast, do you not think it wise to permit easy removal for charging, ... in case of .... ??? :scared::scared::scared:
Al.
don't worry about the battery problem Al,it wont come off the shelf anyway!:clown::clown::clown:
J.
as i don't like wires showing :laugh:i had to cut away the radio plate for the steering servo
i angled the cut on the underside so as not to cut the slot to big
have just about finished the radio plate:cup-2:
needed a bit of jiggling around and:w00t: spacers making
but came out pretty good in the end
the servos are held in with 3mm stainless steel SHCS
the ripmax alloy arms on the futaba servos are part numbers............
P-SOA01M3FT.......single arm with a 3mm thread
P-SOA05M2FT.......double arm with a 2mm thread
well i had to strip down me radio tray as when i came to put it on found
that the battery was to close to the steering servo arm:cursing:
so what can i do ................here was the simple fix as the battery needed to
move back 10mm from the servo arm
i made 2 off set alloy posts:laugh:this then lets the battery slip between the
battery posts with 1mm clearance either side of the battery
K....
This is the difference between bast****, sorry Keith, nice people like you, and poor old me - you've your personal engineering shop and do a brilliant job, and I meddle with whatever tube appears to fit!!
Jealous? OF COURSE!!
Keep up the great work and get it finished before the next snowfall!!
Al.
just what i need!!
Hi trebor,
i was only asking super the other day and saying how i couldnt mount my battery!!
I have exactly the same set up and currently in build,don't suppose another 2 of them posts could be made??
Nice job like it!!
Westy
K....
