Robert LoSciuto
Hi I have the losi dbxle and the turning radius is a joke. Any ideas on making it turn better, not sure if it needs a stronger servo? Thanks
Thanks, seems tight, any ideas on a good servo!Check the servo the servo saver. Make sure its tight.
Better servo will always help too
Thanks Wolle! I will give it a shot.Hello Robert,
I use for the DBXL the Savöx SV-0236 servo this one is stong and quick, runs now more than 2 years without any problem.
Wolle
Thanks Marley I will!i agree with wolle robert. savox servo for the steering. i had simliar probs myself till i bought the savox now turns with great torqe & alot better..let us know how you get on with it..
Wow yeah it is. Maybe i will look into a better transmitter that i can adjust the steering better. Thanks whoduh....The stock steering servo in the DBXL E and 5ive T are a re-branded Savox SV 236.
Savox
Stock Losi 900S
Whoduh are you sure because my servo was no branded Savox, it looks different. Bought my car 2 years ago in the K&N version, this can be the reason why.
Wolle
Thanks for the servo input. I have the electric one and I will say she is a rocket on 8s. I ripped a dog bone out and cracked a A arm. But thats because of the 15 degree weather and doing snow bank jumps. Wolle and whoduh I think run gas. They could tell you better on that version.Check out the specs on the Spektrum S9020 servo. It is a monster at 7.4v and fully waterproof. The Hitec D845WP is another good solid waterproof servo with a ton of torque at 7.4v. I use both servos in different applications and I am amazed at the response and strength. I have a few questions for the dbxle guys, if I could ask?? I'm looking to buy one and need input- Thanks G-Man
Yeah i'm going with savoxI have a mtxl, are you guys running the s9020 as a single or dual servo setup? The savox one as well
