t2boats
Hi all, been a while since I last run my baja. It has a 2.4Ghz system fitted, came to switch it all on earlier, which it did fine, the usual bleeps and flashing lights momentarily, but the receiver and transmitter don't seem to "talk" to each other??? When I opened up the receiver box inside there is a little red light which illuminates twice every second or so, which I rememeber seems normal for it. I fitted a KillerBee some time ago which winks green quite quickly, as it always has done. If I press in the "set" button on the receiver, its red LED flashes quicker, as if it's to mate with a transmitter, like it's searching for one.... Even though the transmitter is on, they're not talking to each other
I haven't changed any wiring or nothing, the only addition was the KillerBee which was connected to the Aux port on the receiver. And it's always worked fine in that setup..
Any clues anyone as to how to reset the system??
Thanks in advance!
Thanks in advance!
