cbaker65
Well Known Member
- Reaction score
- 4,599
I agree ???You posted as I was editing my post.
It doesn't make sense to continue with a old 2bolt engine.
This the time to upgrade to better engine regardless of 320 or 23-31.5.
The 4bolts are much stronger.
I wouldn't bother fixxing the 2bolt.
Any base 4bolt zenoah or cy is going to be better then your 2bolt. Apparently you wanted more power,so you added the big bore kit. They can be good but they also can have an issue with heads and not enough sealing force: 2bolts vs 4.
Whether it's a new engine or a long block is up to you and your wallet.
My vote is start with something other then a 2bolt.
Good Luck man.?
That was actually very well said. And to be open I didn't know the 2 bolts were so "bad" i mean obviously there will be a heck of a difference in compression in a 4 boltYou posted as I was editing my post.
Good Luck man.?
And with a 4 bolts there's much more options for headkits and such ?That was actually very well said. And to be open I didn't know the 2 bolts were so "bad" i mean obviously there will be a heck of a difference in compression in a 4 bolt
Won't regret it if you got my motor ? haul ass in you lil fg.I have a 26 cc 2 bolt? I'm itching to go 30.5 4 bolt?
Could do, but the obr is better value, longblock is 295 and that build is like $266 ? an the obr has a billet case and makes (allegedly) 1+ hp more , so I'd get the obr. Esp ain't slow tho ?
True ? up to u ? I'm team obr ??Mmmm yes but then y don't get build it?
44 more for a billet case and no powa ?Ddm build $251?
Didn't know that ?+ I'd have mod the crank case to get the motor to fit the FG? grinding a billet case will feel wrong?
There's a fg quick release mount for running a 320, I've been thinking about doing it. ???
