- Thread starter
- #21
That's why I said take it apart before you ran it again.
IDidn't run it at all and I shouldn't have to take it spark apart I just got out
Ops it
I live in Minnesota and thanks for the infoWhere are you located?...... One full tank at idle, one full tank at idle but raise the rpm a tad, another tank doing 1/4-1/2 throttle blips across the yard. After all that you should be broken in. I had a lot of trouble tuning until I was able to hear a good tuned motor. Post up some vids if you are unsure.
And for whoever wanted the old motor sorry it does have to go back
Where is the link for your videos and where are you locatedWhere are you located?...... One full tank at idle, one full tank at idle but raise the rpm a tad, another tank doing 1/4-1/2 throttle blips across the yard. After all that you should be broken in. I had a lot of trouble tuning until I was able to hear a good tuned motor. Post up some vids if you are unsure.
My name is Sam I live I Minnesota I work as a maintenance tech and do welding on the side and play with all kinds of small enginesWhere is the link for your videos and where are you located
Does anyone know where to get a good deal on tires also and how to do the flywheel screen modDoes anyone have a good video of engine removal for the rampage I mean I can figure it out but I really don't want to mess anything up
My break in method is start it then drive it like you stole it.I got a hold of red cat and they are sending me a new motor should be here Friday and it's a 32cc insted of 30cc yay also what is the best break in method for it thanks
So I got the new motor put it in and this one won't start I tried everything s and it won't even pop off at allMy break in method is start it then drive it like you stole it.
Many will disagree but it works for me
Richen it up a little just to make sure it's getting lubed
New carb toSame carb or did they send you a new one with the new motor?
What is your break in methodWhat carb, settings and are you using a new plug?
The carb on the 32 is equivalent to a Walbro 1107Post #24
