- Metro Detroit, Michigan
A'ight y'all, All is well on my end. However, my kill-switch failed me today. Ideally, I go out get a full run in and run out of gas and call it good because i'm bored. Well today I somehow blew a bead lock and sent my tire foam all over the place. So no biggie i drive it back to me and press kill button on transmitter...and nothing. No biggie. Hit the switch on engine...and nothing. Grabbed my gerber off my hip and simply pinched the fuel line to kill engine.
So, as far as my understanding its a switch. Ok, got it. A normally closed switch. So, you press button on engine or on transmitter whatever channel you have it wired to it should open said switch and kill power aka ignition in our case. Well that didn't happen.
With all that being said is this something as simple as I dropped a lead off of my ignition coil? Would motor stay running like that? Flywheel is still turning its still generating power so it really wouldn't die? Or am I overlooking something? Or UNDER-looking something?
With engine off, i press my button on TX the kill switch still seems to work. Buzzer and led....and NO i haven't looked at it yet.
