My 5iveT v1.5 basher build thread
Thread starter #1
Basher5iveT420
LSF Plus Member
PLUS member
Likes
166
Broward county
What’s up fellas!
I’m looking to do a few upgrades
so far i have already ordered a new radio Futaba 4PV so I can properly operate a kill switch, Turtle Racing air box with the Hpi filter and Outerwears for both filter and pull start
I would like to upgrade the exhaust, the engine is a stock 29cc 4 bolt..
Can someone please recommend one that will work with the stock engine and where to purchase.
Also the stock tires seem good, but I would like to find something better. I mainly play in dirt fields and grassy fields not a lot of pavement. What are good options ?
7F1983A9-72E7-4EC7-A8ED-E06CB9D4F404.jpeg 7F1983A9-72E7-4EC7-A8ED-E06CB9D4F404.jpeg
Likes
18
This morning I received confirmation that the Bartolone fits the 2.0. I contacted Bartolone and asked: Does the Bartolone 32cc Tuned Pipe fit in the NEW Lost 5iveT 2.0? Their response "Yes Sir." Hope this helps
Seandonato73
Likes
953
If you can still get them. I really like pro line trenchers. the baja front size is the same size as the 5ive T. They do well for me on my dbxl. Idk if they can still be gotten though
Thread starter #6
Basher5iveT420
LSF Plus Member
PLUS member
Likes
166
Broward county
So I couldn’t resist and had to order a new exhaust, I went with a
- Bartolone Rear-Mount Tuned Pipe for Losi 5ive - Raw...
What I would really like to upgrade is the steering servo and throttle servo.
Can someone please recommend Some good servos I mainly bash
dirby
Likes
140
Dothan Al
you will need the metal mounts for the steering servo.
DDM has the Bartalone pipe for the 320 engine in the 2.0 losi 5t.
Thread starter #12
Basher5iveT420
LSF Plus Member
PLUS member
Likes
166
Broward county
Ok, so I bought a used Losi 5IVE-T RTR AVC: 1/5th 4WD SCT RTR.
The guy i bought it from told me it was the 2.0 edition.
The deal was for $580 so I jumped on it before doing any research
Turns out it’s just a regular 5ive t, I was tempted to sell it and just order a new 2.0 edition but I figured wtf I already own this one...
About 10yrs algo I owned a Hpi Baja 5b, And I would order all my upgrades from DDM. And to my surprise DDM is still around and has tons up upgrades for for the 5ive T :cool:
I want to keep the upgrade list short and simple. This 5ive T is well built out the box
I have cart wheeled it countless times with zero broken parts. My baja I would break something every tank.
So I hit DDM and ordered a few items that I felt were mandatory.
NGK CMR7H Spark Plug
Outerwears Pull Start Cover w/DDM Logo - Orange
Outerwears Airfilter Pre-Cover - Orange
Turtle Racing Billet Air Filter Box for Losi 5ive (HPI Filter Version) - Raw
Air Filter Set for HPI Baja 5B/5T/5SC
20ml Bottle of Air Filter Oil
Multi Charging Adapter
Killer RC “Super Bee” Failsafe/Kill Switch Combo DDM 12” Reinforced Muffler Tube w/Clamp
Axis R/C Kage Keeper Clip Tethers Outerwears Shockwears for Losi 5ive - Orange
Shock Rebuild Hardware Set (4) TLR 5IVE-B, 5IVE-T, Mini WRC
Team Associated Green Slime for Shock O-Rings RC Piston Stopper - SILVER
Fataba 4pk radio
Hitek D-845 servos
crucialRC
Likes
508
Maryland, USA
Fataba 4pk radio
Hitek D-845 servos
Cha-ching, cha-ching. I love that sound!!!!(y)
Thread starter #16
Basher5iveT420
LSF Plus Member
PLUS member
Likes
166
Broward county
What exactly is it that I need to install the Hitek D845 servos on the losi 5ive t?
Some are saying they drop right in others are mentioning some type of spacer ?
Also can I used the 845 for both steering and breaking ? I ordered 2
Whoduh
Likes
404
Fairfax, VA
You can use 1 D845 for steering and the other D845 for throttle/brake.
Also..if you didnt get that Rock Armour servo brace that dougstar mentioned....you may want to look into getting it or something similar. The 5ive has a STUPID amount of flex when you apply the brakes.
If you do get the brace...you may have to modify the case of the D845 you use for throttle/brake....its going to depend on if you get the rounded case like dougstar got (no mod needed) or the squared off case like i got (mod needed).
Losi came out with a servo brace for the 5ive T 2.0 but i don't know if it will fit the 5ive T you have.
Links to both are below.
http://www.davesmotors.com/Search-Page/?search=5ive servo brace
