ADA intake manifold question
ive heard the same thing by a couple of big name engine builders down here, if your going to use the alloy manifold use paper gaskets as its the teflon gaskets that warp and cause the air leak, thats what ive been told anyway.
Are you using a starter cover? Have not had any problem with grass since i installed one of those. Looks like your engine might suffer in the long run due to the lack of the funnel the cover provides for the cooling air.
Yes I have a Outerwear pre filter on the pull starter cover just put one on the bottom of the case after picking up a rock and messing up my flywheel. LOL Have not tried running the full cover since i put the case pre filter on it. When you have the engine running you can feel the air blowing over the cylinder. As I said never had a problem with overheating.
