Rustler50
Well if you read my previous thread titled "gear mesh" you guys know I was having starting problems. Well I decided to take the engine apart again and inspect it more with my dad. We found that the bearing that is on the shaft that goes through the piston failed. The pins were smashed, and broken. We believe that the pins scratched the side of the piston and put tiny dents on the top of it and to make things better the piston ring was jammed tight in the piston. I honestly don't know how I missed these things prolly just was in a hurry. So I decided instead of fixing the engine to just by a new one. So I was thinking about getting this one: http://cgi.ebay.com/29cc-Billet-Hea...ccessories&hash=item4ce8f620c6#ht_1673wt_1110 my spending range is around 200. So if you guys have any suggestions or comments shoot away. Also the sad part is I got the dominator V2 pipe and have yet to be able to run it...
