Get the butter flavor and you will catch more.
Get the butter flavor and you will catch more.![]()
Maybe I should clarify what I use vegatable oil or Pam for; NOT for lubricating anything...I spray the chassis before running in mud/wet sand...the veggie oil reduces the amount of crud that sticks to the belly, around the lower suspension components, etc,
After a mud run, I clean the lumps of crud off by hand, then spray everything down with Simple Green to get the junk off, and it will also cut through the canola oil and get it off. Then everything gets lubed with proper lube oil
