DBXL Again with similar issue.
Marky Marc
New Member
Sup fellas, so awhile ago I had an issue y’all helped me out with when my car wouldn’t accelerate and it ended up being the bell screw snapped. But now it’s doing the same thing, not accelerating when pulling the throttle down. The screw is still there n everything but still won’t go. Any ideas on this? I’m stuck in the mud. Thank you
As Rep732 says check all your drive pins, also check the pinion gear, this has a habbit to work loose (even with threadlock!!). if all this checks out then with the motor/engine off, just lift the rear end up and spin both wheels by hand at same forward and visually look at the center diff and check the spur gear is spinning, then do the same for the front. It should spin freely and smooth.
