arp35
Air Filter and Shock Piggy Back reservoirs
Hey,
I am new to the forum and recently purchased a KM 3.0 Baja. I have a couple of questions for the experts.
1. The air filter housing is the orange aluminum cage. I unscrewed the end and slid out the foam. I was kinda surprised to see that there is no inner cage to keep it from collapsing. Is the inner cage not necessary with the foam filter? It also came with another filter that is yellow and appears to be an inner/outer filter. I don't think it would fit well inside the aluminum housing. Is it just a left over from the old stock filter? Also, if the foam filter I pulled out doesn't need an internal cage, does it need foam oil?
2. The shocks have small reservoirs (piggy backs) at the top attached to the shock cap. It also has a small horizontal screw at the top. Is this screw for filling the shock reservoir? If not, do I still have to unscrew the shock caps to check the fluid? What is the purpose of the side reservoirs? Update: I searched around and found this info http://www.rcuniverse.com/forum/m_7429197/anchors_7438456/mpage_1/key_/anchor/tm.htm#7438456
I am still not sure what the horizontal screw is used for though. Update 2: I found the answer to #2 here: http://www.hpibajaforum.com/forum/showthread.php?t=44641
I will leave the question up in case anyone else has the same question. Can anyone help me out with question #1?
Thanks in advance.
Alan
Hey,
Thanks in advance.
Alan
