monotheist
- Melbourne, Australia
Bean studying the breakdown manual and have noticed a few things I don't fully understand. Firstly the diffs. I know the center is just a spool (ie. locked) meaning that at any given time the power must be going to at least one front and one rear wheel. This was the same arrangement I had with my Losi LST and found the front wanted to push a little through the corners because of this. Doesn't seem to be the case with any of the MCD vids i've seen as they appear to turn pretty well (much better than my Baja5b).
Also what kind of diffs are those? certainly not the typical spider gear arrangement im used to. Are they a torsen diff and are these filled with silicone diff oil or grease from the factory, if so what weight? They don't appear to be as I cannot see any kind of rubber seal on the ring gear you would normally find on a oil filled diff. The output shafts also don't appear to be riding on any bearing/bushing so they may develop slop over time (has anyone noticed this?) Again this was the same as with my LST and did notice a fair amount of play due to wear over a period of a few months use.
I guess what I really want to know is how do you guys service the diffs and did you do anything before taking it out for the first time.
Finally I have seen a few install a grease nipple on the diff housing. I was thinking of sealing the lower part to the chassis and filling it approx 1/4 full of transmission oil (Redline shockproof) for lubrication. Sound like a good idea or should I just stick to grease.
