Baja 5B starts and instantly stalls
GoneRogue
Swindon UK
Hey Guys,
Just engine swapped my baja as my last engine went capoot. After installing the new one I went to see if it started and it would start but it would instantly stall, no throttle or anything applied just stalls after 1 second. I have had this happen to me before and it was an air leak from the exhaust port but I have made sure everything is tight and I don't see anywhere there could be an air leak. I have also tried replacing the plug and that didn't help, the other one also didn't look spoiled either. Maybe I need a new carb?! Or my fuel lines are not working as they should?. Not sure what else to look for, or anyway I can find an air leak if there is one. Any advice would be much appreciated.
check you have your fuel lines the right way round mate, clunk line to the bottom and top is return line,
also check the insulator and carb gaskets, make sure the pulse hole isnt clogged with a piece of gasket or crud (y)
