Baja 5T or Baja 2.0 w/26 cc Zenoha engine
goostlyrich, what do you mean by checking the spark...? and as far as the filter goes, i ordered the outerwears pull starter, shock covers, and pre-filter, do i also need the redneck? is installing the turtle clutch easy ... or is it a big hassel
Finaly i took the car for a spin offroad .. check the video : http://www.youtube.com/watch?v=fnwAl7tgPL0
check it out /// :)
OK .... I went to my local hobby store today and was told the following :
That this particular dispatch included the Zenoah engine due to stock shortage in HPI of the CY engine...... so i guess i was lucky to get the 26cc zenoah engine ... thank god. ..
If u have any more questions please let me know ...
cheers
Talked to about 50 others on other forums and you are the only one that got a Zen in a HPI baja. There are places that offer at a price to up grade your order to a Zen which I think if truth me know is what happen. Check out this thread which is only one of several talking about this. Either way have fun.
http://www.hpibajaforum.com/forum/showthread.php?t=70655
As far as the Turtle clutch system it does away with the problem with the pinion bolt breaking, has a MUCH better CB better machined and rounder as well as machined out of one piece, has bigger CB bearings, enclose the clutch to keep dirt out does away with the POOR plastic CB bearing holder that flexes and can cause spurs to strip, gets rid of the POOR 2 piece plastic gear shaft bearing holder. I will not run mine with out it or a good kill switch.
A good kill switch can save you a LOT of money in the long run as well as could keep you out of a law suite and no a fail safe is not good enough alone.
