Baja carb
Busted baja
I have the walbro 990 carb which worked fine, I changed the primer bulb and put on full force fuel lines.now the Baja won’t start.and the primer is full.any ideas?
sounds like put back together incorrectly. i'd get the exploded diagram and go through everything you did very carefully.
