Baja symmetrical steering servo links
DonnieD
Wyoming,IL
So I bought the symmetrical steering for my Baja and bought better steering turnbuckles but the servo links are junk and one keeps popping off and both have so much slop…any suggestions what and where I can get a set of good ones?…tried finding something on YouTube about them but struck out and looked on DDM and Detroit performance too and didn’t see anything
not sure about the servo horn screw..M2 maybe it’s a Rovan servo and the little turnbuckles right now are 35mm hole to hole
I’ve got the Fonzie ones but I’m using the FLMs with HPI rod ends for my lightweight build.
I’m using Bonesteer which is a sym steer system.
I’m talking about the links that attach to the servo horn…little bastards…and I’m not above using plastic as long as they don’t pop off every time I run and don’t have a buttload of slop
There are ways you can tighten the plastic joints, also you can do the same as Spents on here. Look at his Bitsa 45 build he’s used a limit strap to hold the arms in case they pop off.
If you make a slit where I’m pointing then put a nut and bolt through it, you can then tighten it around the ball joint.
