Be honest
bigdipperfred
somerset nj
How many you guys bolt your body down.On your losi 5t or do you a have different method . i was bored and lazy didnt bolt it down today. lost the threaded hardware in the roll cage.
evssv
Bristol uk
top tip.....remove all 4x body side cage screw things and super glue them in....(y)...and yes I use these every time....(y)...and yes I almost lost 2x of mine at may bashfest on the grass....:eek:....luckly found them and did the glue trick.....:cool:
crucialRC
Maryland, USA
If its anything like the Vekta.5 it's a big PITA. I even bought the clip conversion for it and it still sucks. Don't know why they make them so difficult.
Whoduh
Fairfax, VA
Ran without them for a while but use them now.
It might be a pita but they do add suuport for the cage if you crash.....that energy has 8 points to disperse over the entire body- front-sides- and back instead of just 4 using only the body clips in front and back.
bigdipperfred
somerset nj
Thanks for the tip going have to order some new ones they went bye bye never to be seen again
Just like my money
TODD
I almost lost mine a few times too. It does stiffen everything up and this is why I bolt my down. I also thought of gluing them in but didn't like that idea too well if I had to change them for whatever reason and also the stress the glue joint will be in. If you look at the new aluminum threaded inserts you will see they have a small hole drilled in them. What I did was run a safety wire through the hole and and a cage bar. Never lost another one and if they do fall out the wire will keep it from getting lost.
bigdipperfred
somerset nj
Thanks I seen the hole I really didn't think they where going anywhere I pulled one out the rest didn't move but lost i them .I just wanted to burn some fuel up had little time to kill.
William E Burrows Jr
Florida
This is a waste of time to even talk about.
You would thing this would be the last thing anyone would be concerned about.
I am sorry I viewed this Be Honest category.
