that sounds greatRCDAD said:Currently the only ratio for our Cats 1:1. I am told other ratios will be available in the future. It comes with everything needed. It mounts in place of the gears on the factory shafts using your factory hardware.The pro already has the aluminum gear plate with the larger bearings, so you are good to go.
If you are running the MT tires the gearing will be higher than stock. More top end but slower off the line.
There currently is a 1.54:1 ratio for the carbon fighter model this is like our 25-35 gearing.
They should have this for the cats in a couple months.
Like Leftnut said, if you have a somewhat souped up engine (ie heat kit) built for little more torque, wouldn't that help a lot in making takeoff less slow?RCDAD said:If you are running the MT tires the gearing will be higher than stock. More top end but slower off the line.
Yes it would me much better then if you were running the stock motor.Like Leftnut said, if you have a somewhat souped up engine (ie heat kit) built for little more torque, wouldn't that help a lot in making takeoff less slow?
Interesting, My MT with a stroked 30.5 takes off very respectably.RCDAD said:The current 1:1 ratio would be a top end ratio for the mt. I would not recommend any higher unless you down size the wheels/tires.
