stock carb settings are 1 1/4 on L and 1 1/2 out on H. same as the other walbro carbs for these motors.
is the plug Wet looking? if the plug is looking very Damp or wet, its flooded.
813 has an accelorator pump in it. so everytime you give the trigger a squeeze you get a shot of gas, where the other non pumped carbs have to depend on the air flowing over the needle ports to draw (siphon) the fuel from the carb. so its very easy to flood a motor with the 813 by simply squeezing the trigger 4 or more times.
deflood the motor as BTB suggested, drop in a new plug no squeeze of the trigger, and give it some pulls.
are you sure any remote kill switch is activated and allowing the coil to spark?
do you have spark?
you can gap the flywheel with any standard business card. same with the plug. any motor with no issues should run fine with these gaps. if not, there is another issue that the coil/plug gaps.
is this a 36mm GP290 topend?
a yr ago. seemed there were a series of the 36mm piston rings that wernt quite true. but it was only a few.
if all seems fine, but it wont fire,im going to say it may be a funky ring. to check this, pour a table spoon full of straight 2 strok oil thru the plug hole. roll the rc around so the oil coats the piston top and ring. its important for you to bring the piston to near TDC of the stroke to close off all the ports from the ring, this way the oil doesn't just run into the bottom of the case.
once you have the piston/ring coated, put the plug in and try to start as normal. if it fires up, then the ring may be a problem, but running it may help seat the ring and get it to seat to the cylinder walls all the way around.
typical starting sequence for 813s
1 turn on tx then rx
2 prime bulb till firm and give 2 more pushes
3 squeeze trigger 3 times, let set to idle
4. pull it over wihtout touching the throatle.
if all is good, it should fire up in 1 or 2 pulls. if it doesn't give it one squeeze of the trigger, reset to idle, and pull a couple times. try once more if it doesn't fire. if it still doesn't fire up, or sound like it wants too, you have something going on.
i have the 813 on my ESP 27.2 which has been rebuilt after 12 to 15 gallons.
3 to 4 squeezes of the trigger, and 2 pulls and its typically idleing.
hth and let us know how your making out.
Tim
