- Flintshire,North Wales
After putting my billet inlet anifold on I took my MT out for a spin.On starting it up which took ages I opened the throttle and it instantly bogged down.I tried various carb setting but it was thew same.
I bought it back to my workshop and 7 screws later it was clamped in the vice with the tank attached and the pipe on.I pulled it so many times the started bust! So I opened it yp and stripped it down.On closer inspection the inside of the mill was full of fine sand( I run in a sandy area with the standard filter on).There was a slight score on the cylinder liner and a very small hole in the center of the piston( Is that meant to be there ???)I cleaned everything and reassembled it (using the same gaskets) I tried to start it with a drill but it wouldn't even pop!!!
I've injected fuel directly into the barrel.
I have put another carb on (WT-668)
The coil has been off but have put it back with a credit card clearance.
The needle are back to standard setting although I've tried different settings
There is compression and a real healthy spark.
Any ideas fellas? as this might just turn into a door stop!
Thanks
James.
Thanks
James.
