- florida
I added a picture above in last post it’s always the little pieces that gets usWhat?
so ya mean it wont apply brakes when pulling against the fuel tube ?I was gonna remove it but because it’s not doing what I wanted it to do. It won’t return back to center let alone apply brakes the opposite direction
the pads may need shimming a tad bob, if theres too much movement the cam will lock when brakes are applied
not sure if the brake rod/ eyelet bit needs to be to the outside on an outlaw, but on a baja it normally goes to the inside not outside
It applies brakes but when I let the brake off the spring doesn’t push it back to center. If I flipped it, it would line up better so I’ll do that, but i was worried about figment the other way.so ya mean it wont apply brakes when pulling against the fuel tube ?
Huge shout out to mr parks if your ever in a pinch send him a female family member or friend for the day and he will send you a servoMan that's a nice servo.
No the losi shocks won’t mount to that and it doesn’t get the shock mount lower. I think the “drop” refers to the dip in the middle of the towerWhat about the rcmax tower? They offer it in the drop too
Or you being strict on no alloy?
https://www.detroitperformancerc.com/product-page/rcmax-baja-drop-style-rear-shock-tower
Will the losi shocks mount though..
No worries. I’m not a huge fan of how irc does business. So I’ll do what I can to not support them. Id like to see another company come out with shock optionsYeah I was just looking at that pdf too..damn☹
Why not go for the adjustable flm tower? I think that will accomplish what you want.No the losi shocks won’t mount to that and it doesn’t get the shock mount lower. I think the “drop” refers to the dip in the middle of the tower
fiddlestick offGet some mod shocks you cheap ass.
what hardware did you use to mount the shocks. Can I just drill out the tower and use the stock losi shock hardware?
