fxdf1584
just ran its first tank through, KM T1000 with the 30.5 and it seems every rull revolution of the brake rotors they bind up, if i pull the truck across the floor its enough to notice, when running it a few times it would even slow the truck while coasting. any ideas? thanks!
also the idle started to fluctuate after running it through the first tank, would hope its not an air leak, i checked every bolt possible the day i got it, pulled the motor and put on outerwears on everything and filled the diff with 10,000k fluid, i did notice the binding brakes out of the box but figured a little running might "loosen" that up.
thanks again for any advice
