Brakes binding on kraken vekta 5
Barber213
Good afternoon to all . I have a question in regards to the kraken vekta 5 brake pads and disc . I’ve had an issue straight out the box where the truck wouldn’t roll freely . DDM helped me out with the upgrading the brakes . I notice after installation the truck had the same issue , but if I loosened the screws that hold the brake it would roll freely . Should I install spring between brake pads and disc . An if so which springs should I order . Thanks in advance .
Red loctite the brake screw where you want it. Also make sure the rear axle bolt isn't trying to unscrew up into the rotor
Thanks for the info . But I put springs between the brake pads and that solve the problem. The first pic has no spring . Even though I upgraded the brakes on it . Thought that would solve the issue . The second pic I ordered the Losi 5t springs and it works .
are the springs factory? i think it should work without them. you're gonna have to learn to adjust and fix things, the big ones need it frequently. if it happens again maybe back out the screws some?
It’s working great with the springs . I used the Losi 5 t springs . Thanks for the advice .
