Rampage mt
Hey guys yet another issue....I believe it's the brakes sticking,the truck will work for a minute then it will stop engine still running however wot move or moves extremely hard.when I push it by hand it rolls hard.i took it all apart checked the gears to make sure but it seems its the shaft that holds the brake arm from the servo it won't move.i cleaned everything put it back together and the arm moved as it should however tryed to run it and it moved 4 feet and same issue any ideas?? Getting really frustrated with this thing given all the problems I've had and the fact it's barly seen driving time...
