atom3624
Terrible pun, and intended!!
I've never been happy with the power of the cable brakes. Not easy when the other truck I run is an LST2 that can lock up all 4 and somersault without trying!!
At best I could lock the rears, with weight transfer of course - most weight going to the front.
I've 'tuning' cable brakes with good pads on.
I've set them very lightly binding at zero - not enough to consider 'drag brake' but same principle - basically to permit more scope for more braking power.
I used a Savox 1256TG on the throttle / rear brakes, and another 1256TG separately on the fronts.
A couple of weeks ago I located a MEGA Savox called the 1230, with 500 oz in / 32Kg cm at 6.0V; 60 degrees in 0.16 seconds against the 277 / 20 and 0.15 of the 1256TG - pretty amazing specs.
I installed it last night and .... an improvement, but not ground breaking (avoided that one!!).
I reconsidered going the hydro route and contacted Mike1970 who confirmed Mecatechs are 'the best' but I shouldn't really need to go there.
I perused the internet - easier than reading the manual - and .... downloaded the manual for my Spekky!!
I found what I was looking for. I'd noticed that the throttle was perhaps 1.5x the travel of the brakes, and couldn't figure out why.
It's called 'Grip Lever A - Brake Trim' on my Spekky 3.0.
It was set at 65% !!!! That's of a possible 125% !!
Of course I set it at 125% 'to see', but reduced to 100% as I couldn't feel any noticeable gain.
Hopefully HAPPYDAYS.COM !!!!
