buckshot X2R hpi baja
hi thanks, got aload of fiddle bits sorted,
steering in and works well, its all adjustable , i have a tiny bit of bump steer which i can live with or will iron out eith adjustment, got to put a second bracket on the upright for the rod end to mount to
front and rear caliper mounts sorted, i made a dummy disc to get the postion right so now waiting for the real ones to get made, twin poys on the front and single for the rear,
upright rod end spacer in and give quite good turnning, not as much as a std baja but i can live with that as i run in the dunes mostly
Coming along really well, the track width gives it a real low stance and will no doubt aid handling.
Needs an engine with a bit of power to get it moving well though, I would have thought. How much does it weigh?
hi cheers mate, be interesting to see what it sounds like, should have it finished this weekend and will test it
hi cheers mate, i thought it was ok, gonna weld some ends on and a flange mount so i can bolt on some silencers
