The pre 2008 internal diffs gears did occassionally fail/break. The diffs were redesigned early in 2008 and I have not heard of anyone suffering any issues with them.
I have the pre 2008 diffs in my three MCDs and have never suffered any failures. Normally the failures occur due to poor maintenance rather than defective parts.
The grub/set screws on the diff output cups most be kept tightened (threadlocked as well) because if they work loose the output shaft gear will eventually move inwards locking the diff and if it happens at speed the gears will fail!!!!!
Clive
Grease the crown and pinion, and grease the plannetary gears.I just purchased the redesigned gears....I hope they fit straight in.
They are freaken expensive.
Thanks heaps for the advise....I reckon that is what happened to the rear diffs as the out drive cups were loose.
However...the front ones were tight. and full of grease...
Do people usually put grease on the outside, or run these dry?
I found the front full of grease outside but the rear to be dry.
thanks for reply.
The diff gears, crown, Pinion, pins, side gears, and case are different from the EVO II to the EVO III. If you want to upgrade the diff to the EVO III, all you can do is buy a compleat EVO III diff and crown and pinion, unfortunately it all has to be changed.
MCD translated to english $$$. lol They are a cool RC, but very expensive to play with.
FG Stadium tires? Hostile slicks provide better traction in gravel. lol Good luck with your mods.
