lordraptor1
anyone have issues with their 26s in regards to the carb? i was out with my baja yesterday finally getting some good running when it started to become hesitant upon acceleration then it died and wouldnt restart.
i went through the day troubleshooting it finally ending in rebuilding the carb (which in no way should it have needed this done yet), and when i cracked open the carb i was in for a surprise. first let me say i used teh pdf from walbros site during the carb rebuild which i do every time i rebuild a carb for a piece of lawn equipment such a s a trimmer, chainsaw, mower, etc and i found it odd that on the pdf there were 2 pieces shown that my wt-668 did not have (which was a first for me).
the parts not on my carb that were shown on the diagram are part #'s 33 and 48a on the following diagram
http://wem.walbro.com/distributors/servicemanuals/WTseries.pdf
i also ran into an issue with part #'s 23 and 24 in that they seemed a little loose (the brass one fell out to be exact while the other i could spin with my finger).
and the place where the little brass plug went looked damaged (probably from teh loose brass plug).
so i need to ask if anyone else has ran into this issue before on tehir baja?
i have been doing small engine repair for lawn tools since i was 11 and was mowing lawns and i have never ran itno the issue before myself.
i now need to come up with some funds so i can buy a new carb because the rebuild didnt work and i know the carb is the issue with my engine but it looks like once i get that taken care of my baja will run the way it should and after all teh aftermarket parts i should be good to go
. only weak links left to change out are the clutch parts which are schedualed for next month and the parts i consider bling (lights, liquid graphiced parts, etc.
). so i would love to hear if anyone else has had similar issues with their carb and how old your carb actually was (i.e. how long have you had the engine/carb)
anyway i
anyway i
