So I was trying to GPS my Baja last night, but found out my RPM's were being limited for some reason. I was originally getting 62.8km/h in the sand on the weekend. Last night, I put the stock tires back on and on pavement, I could only get 59.X km/h no matter what I did with the high end needle. It will accelerate nicely, then noticeably stops at a certain RPM. I'm assuming the crank bearings are starting to wear out. I figure I should start looking at all the replaceable items anyway for this winter for a rebuild when I swap out my engine. Does anybody know if the TFE Ceramic bearings will work? They are apparently for a beveled crank. Do these copies have a beveled crank? I'm assuming so. Thanks for any help!
