Chimera EP Pro 10,000mah
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
I rewired my sons EP Pro for some better packs.
It is now parallel running 2 x 6s 5000mah. This should give him a good 25-30 minutes of run time.
They come with 2 x 3s 3800mah, ran in series. That equates to 6s 3800mah. It was only getting 12-15min of run time. :(
Yeah the stock 2 just don't make the cut, I'm run I g 8s with two 5000mah 40 in series and it has excellent run time.
Just curious, what benefits (or drawbacks) are there for running equivalent setups wired in series vs parallel? For example: two 3s 5000mah packs wired in series vs two 6s 2500mah packs wired in parallel?
In the end you get 5000mah at 6s while running.
It all comes down to charging capabilities.
The 2 3s 5000mah would need to be charged at 3s 10A (1C) Parallel Charging and 6s 5A (1C) Series Charging. So charger capabilities would need to be 6s @ 5A or 3s @ 10A.
The 2 6s 2500mah would need to be charged at 6s 5A (1C) Parallel Charging and 12s 2.5A (1C) Series Charging. So charger capabilities would need to be 6s @ 5A or 12s @ 2.5A.
So in the end your charger limits the options as above.
bullaculla said:
Or you could just keep it simple and charge one battery at a time.
When you run 2 batteries in series like this it is best to charge them together to make sure the cells are matched across each battery. The closer they are to each other the better they will deplete. Then you don't have to worry about a cell dropping below the min.
