G
In the end you get 5000mah at 6s while running.daravelli said:Just curious, what benefits (or drawbacks) are there for running equivalent setups wired in series vs parallel? For example: two 3s 5000mah packs wired in series vs two 6s 2500mah packs wired in parallel?
When you run 2 batteries in series like this it is best to charge them together to make sure the cells are matched across each battery. The closer they are to each other the better they will deplete. Then you don't have to worry about a cell dropping below the min.bullaculla said:Or you could just keep it simple and charge one battery at a time.
