Hello all
I need help. This is the 3d time I've had a clutch bell shaft snap off. This has happened on my buggy and now in my 4WD FG Sportline. Each time it happens I have to end up buying all the parts again be cause I cannot get the pinion gear off the broken shaft and removed from the clutch carrier so I end having to waste all those parts. The gear is attached with 2 grub screws that's a b@#$% to get off. The screws are stripped which makes it more difficult and I cant fit nuch in there but an allen wrench. I have a screw extractor kit but i cant fit a drill in there to try to get it out. I've attached pics.
Anyways if anyone has any advice on how to get this off be much appreciated. I also thought about maybe grinding off the other end of the broken shaft but that steel is hard and I dnt have a powerful enough grinder. The best bet would be if I could get those darn grub screws out and pull the gear off the shaft and pull out the broken shaft o would be able to reuse everything and only need to get a new clutch bell.
Anyways thx in advance
