G
Guest
Guest
rcgasser is correct. That is a zen housing in your photo. You need a CY or HY housing. I snapped another pic for you. You can see that the Zen carrier is deeper than the CY.ChuenouXiao said:RCdad? Deluge?
I new about flywheel cover, good thing I always use a TR clutch housingRCDAD said:When ever you throw a Zenoah in you need to swap the flywheel cover and the clutch housing for it to bolt in properly.
Does this mean I can't use the four original bolts for the clutch housing from OBR onto the HY or CY housing? Do I need the HY and CY bolts specifically or are they the same length and size?RCDAD said:rcgasser is correct. That is a zen housing in your photo. You need a CY or HY housing. I snapped another pic for you. You can see that the Zen carrier is deeper than the CY.![]()
You sure Rcdad?RCDAD said:The bolts will be fine.
You're always my savior Rcdad... thanks bud!RCDAD said:Yep...I've never had a problem with the hardware.
Or bust out my ElconRCDAD said:Agreed.Just to save yourself some headaches, I'd start with a new clutch and bell.
