buzzkill
Mad?scientist
Like I said is there anything to stop you from adding 2 extra bolts ? and use a 4 bolt gasket ?
looks like this guy did it !
and this is why I asked here !!That TS case is designed to be 2 or 4 bolt. A stock zenoah or even tr/obr case , that is designed for 2 bolt, doesn't have the space to just drill 2x more holes. That is, if the case even has the same size transfers and stuff. I wouldn't waste my time, just buy a long block off obr ?
Of course you do.??If your ultimately not going to use it, you have nothing to loose other then time. I say try it.
