BrawnFG
'Morning all.
Apologies that this sounds like a bit of an advert, but after 2 months off the road I'm rather chuffed with myself getting the Baja going again.
I've had some trouble finding a decent stiff radio plate to replace the standard plastic one, main reason is to improve the brake performance (standard rear disc). I got a King Cobra one off ebay for £25, but discovered that to fit it I'd also need new throttle/brake linkage and would have to modify the front part of the roll cage a little. Sod that.
I decided to solve the issue completely by designing and making my own plate to match the standard plastic one. Plan A was to buy a sheet of 2mm ally for a tenner and dremmel it, but I found a guy on ebay who laser cuts stuff to order. Half an hour later with a set of callipers and some CAD software I'd knocked up an exact replica. The fela on ebay only charged me £8, bargain!
The pics below are the result of my efforts, better than the aftermarket stuff, and cheaper too!. (if anyone wants the radio plate design message me and i'll send you it in PDF and DXF formats and point yo towards the guy that cut it for me)
The main problem with the aftermarket tray i tries, throttle servi in wrong place, and cut outs the wrong size. Battery bar also raised the CoG.
Solution, have one custom made
all to make the finished article
(n.b. outer roll cage and rear wing lasted about 3 mins into the first run, ad I'm currently planning a full alloy roll cage
