cy and a kingmotor engine
It will bolt up to your KM if its 2 bolt. May have to change crank from 2mm stroker to 28mm unless head is cut for the 2mm. last option stack gaskets
well for for $43 more you get the cy crankcase with bearings and pull your manifold,carb, pull start parts off the old engine, otherwise the km crankcase will be fine to use
