Thanks
I have finally got around to installing te head kit, and Thank goodness I am fairly good with a wrench! The kit does NOT come with any instructions!?! The only problems that I came across were that I had a bit of trouble with getting the piston into the cylinder (I found a small burr on the cylinder that I had to remove) and there is a space that is included for attaching the ignition coil, but a longer screw for the spacer is NOT included. A trip to Homedepot solved the problem. I can't wait to finish up the other stuff I'm doing to my machine so I can hear it scream! :cool2:
