CY billet head kit: any tips?
eyring2210
Troy, NH
I just ordered a CY billet head kit from DDM. Does anybody have any tips on the install of this? I'm an aircraft mechanic so I am not worried about the basics, just about tips to make the engine run better or more powerfully while I'm in there. Thanks.
don't over tighten the cylinder bolts (5 Ft Lbs torque specs) or the head bolts (not sure but i think 5ft/lbs torque also)
overtightening them will cause the sides of the cylinder to push inward between the bolts and will cause some issue.
not sure if you have to stack cylinder gaskets to make room for the 2mm stroker crank with these.
while your doing the 2mm crank, toss the CY crank bearings and buy a set of Fast Eddy Crank Bearings (standards 13.00 or ceramics 39.00) the cy crank bearings tend to fail a bit early and cause un needed down time and repairs.
Thanks
I have finally got around to installing te head kit, and Thank goodness I am fairly good with a wrench! The kit does NOT come with any instructions!?! The only problems that I came across were that I had a bit of trouble with getting the piston into the cylinder (I found a small burr on the cylinder that I had to remove) and there is a space that is included for attaching the ignition coil, but a longer screw for the spacer is NOT included. A trip to Homedepot solved the problem. I can't wait to finish up the other stuff I'm doing to my machine so I can hear it scream! :cool2:
make sure you line up the ring so as shown here ....there is alittle nub along the grove the ring fits in.... that nub goes inbetween the opening of the ring...if you don't the piston wont go into the head
The only problems that I came across were that I had a bit of trouble with getting the piston into the cylinder I found a small burr on the cylinder that I had to remove
You didnt remove this did you???
Also make sure the dot/mark on the piston head faces the exhaust port side of the engine
