Goof off works great also in removing the paint from the stock body.blak__jak said:i got the factory paint off mine with acetone. it wipes right off. just got to use alot of clean paper towels. it's hard to tell from this pic but its painted with a color shifting paint that changes from almost black to redcat blue to purple depending on how the light hits it. i'm not much of a painter but would rather have anything other than what 40,000 other people have.
You know that will make me just want to paint one up.blak__jak said:i still would like to see what the grafil body looks like on the d/r rcdad if you could just sit one on there so we all could get an idea of how it would work that would be wonderful. thanks ahead of time.
Thanks! I'm getting ready to strip and re-paint mine, the tips saved me some grief.blak__jak said:you will find that the factory paint will pretty much just wipe off with the acetone but the lexan will fog up. if you go over it again with clean paper towels and acetone you can eliminate most of the leftover paint and fog.even if you have some fog left it's on the inside and won't hardly show with new paint over it. the one thing you do have to be careful of is not to get the acetone on the outside part of the body because if it fogs up it will show.
Good luck. Post some pics when your done.Chief409 said:Thanks! I'm getting ready to strip and re-paint mine, the tips saved me some grief.
Just print up a photo on brochure paper then use Amain picture glue to glue it to the inside of the body. Then just spray the rest. It's really easy. Then you can drive her hard all day long.rampagemt said:I will rcdad!!! If only I had the skills to paint a hot babe on mine that way I can drive her real hard
