Pull the spark plug out or use a known good plug and with the coil wire attached to the plug touch the ground electrode to something metal on the engine (the head or the engine case) and give the pull start a few tugs. If the ignition is working you should see a spark bridging the gap between the center electrode (copper center) and the ground electrode (the L on the bottom of the plug). The DBXL manual may have a trouble shooting guide to help somewhat.
Man that is a tough nut to crack! Where are you located? I know it is a big PIA but have you tried to reinstall the stock head and piston to see if it runs? An engine needs air, fuel and spark to run. I wish I could lay my hands on it. The spark is run off.the flywheel by a key, so as long as the coil is gapped right and you have spark timing shouldn't be an issue. What carb did you install and does it have a choke? You could try to pull the spark plug out, put a few drops of fuel in the cylinder, reinstall the plug and see if the engine sputters. I know it gets frustrating but you will be a pro when you get done!
