DBXL-E High speed gearing
Discussion in 'Losi Desert Buggy XL' started by modojojo, Oct 8, 2017.
  1. modojojo
    modojojo New Member
    Oct 2, 2017
    3
    0
    Hi all, just got my DBXL-E and have some upgrades coming in the mail. I'm looking for high speed gearing options. I know the company DGI makes gears for the DBXL, are they compatible with the E? Are there any other companies that may make gears that fit the E
  2. MGP
    MGP Well-Known Member
    Aug 14, 2017
    50
    2
    DGI is for the gas version won't fit the Brushless motor.
    RC Monster make the strongest gears for the Brushless 8mm shaft 1.5mod pitch
  3. Timbo
    Timbo Active Member
    Feb 16, 2017
    32
    6
    Peterborough
    Just changed the pinion on motor will be easiest option, ok if you want to do some speed runs but remember you will kill your run times !
    There pretty quick out of box so may be happy as it is :)
  4. MGP
    Aug 14, 2017
    50
    2
    Just like Timbo said they are quick and pretty nuts out of the box there is really no need to change pinions. Also along with less run times you have that chance of over heating your motor and esc.
    The batteries that my freind runs in his are out of stock at the moment. SMC 4s 8000mah 90c constant
    I run SMC 4s 9200mah 90c constant in my 5T but these don't fit in the DBXLE.
  5. modojojo
    modojojo New Member
    Oct 2, 2017
    3
    0
    I just wanna make sure I blow my friends 5B out of the water, I already ordered a mgm esc with a Lehner 3060/8 and 12s ( 2 turnigy 5000mah 6S batteries. I found that Kershaw makes 8mm mod 1.5 pinions from 9T up to 22T then they have a 26T. I may experiment.
  6. Timbo
    Timbo Active Member
    Feb 16, 2017
    32
    6
    Peterborough
    Blimey what motor is your mate running in 5B ? the std 'e' car would beat a std 5B petrol anyway ! you will make it crazy quick but your run times will suffer for it, on 12s nothing should be anywhere near it ;) mind you don't blow tyres off the rims ! keep us posted
  7. MGP
    Aug 14, 2017
    50
    2
    Go to RC Monster they have the best pinions on the market ask me how I know
  8. Timbo
    Timbo Active Member
    Feb 16, 2017
    32
    6
    Peterborough
    Don't order a pinion until you have run in on 12s ! top speed will be crazy anyway, with brushless the higher the voltage the higher the RPM
    RPM is volts x kv rating on motor. 8s = 33volts x 700kv motor ( example ) = 23100 rpm / 12s = 50volts x 700kv motor = 35280 rpm
    Thats massive rpm increase, what kv is std motor against new one ?
  9. modojojo
    modojojo New Member
    Oct 2, 2017
    3
    0
    Yeah I'm going try out the stock pinion first. The Lehner 3060/8 winds = 875kv the motor and mgm 25063-3 x series Esc can handle up to 15S
    Esc specs are
    Max RPMs
    250.000
    Max. peak current (peak 5 sec.)
    360 [ A ]
    Max. continuous current (for full throttle)
    250 [ A ]
    Number of Li-Pol, Li-Ion feeding cells
    4 - 15
    Here's a Video of the same motor speed controller combo I ordered he's using 14S instead of 12s:
    This car has a Lehner 3060/8 motor and an MGM Compro controller, with two 7S MaxAmps batteries. Max full throttle power is 14.7 kW (20 hp) with max peak power at 21 kW (29 hp). Good to see the car Is sturdy.
  10. KrazyDbxle14
    KrazyDbxle14 Member
    Nov 8, 2017
    12
    1
    New Jersey
    it fits! or make it fit, lol
    I love my long playtime on these cars..
  11. KrazyDbxle14
    KrazyDbxle14 Member
    Nov 8, 2017
    12
    1
    New Jersey
    this is on 14t pinion to start with stock motor.
  12. Timbo
    Timbo Active Member
    Feb 16, 2017
    32
    6
    Peterborough
    What sort of run times are you getting with those batteries ?
  13. KrazyDbxle14
    KrazyDbxle14 Member
    Nov 8, 2017
    12
    1
    New Jersey
    40-45mins for me. For 9200
    30 mins for the 6700
    Both SMC BATTERIES
  14. Timbo
    Timbo Active Member
    Feb 16, 2017
    32
    6
    Peterborough
    Thats impressive run times ! no going back to petrol for us now :)
    KrazyDbxle14 likes this.
  15. MGP
    Aug 14, 2017
    50
    2
    These SMC Batteries are great I’m getting 25-35 mins out of them in my 5T with the 9200’s and they are priced right too.
  16. Timbo
    Timbo Active Member
    Feb 16, 2017
    32
    6
    Peterborough
    A 5T is a heavy car so that is impressive ! nice to see brushless getting the longer run times now, we just need the new tech Lithium metal batteries to be released and we will see double the capacity :)
  17. KrazyDbxle14
    KrazyDbxle14 Member
    Nov 8, 2017
    12
    1
    New Jersey
  18. MGP
    Aug 14, 2017
    50
    2
    Yeah I find myself running the Brushless 5T more than my gasser. Especially when it’s late and I want to keep the noise down plus the lights on the Brushless one make it fun to drive at night.
    I’m in the process of building a 5T plow truck with all the parts I swapped out on the KM X2 with LOSI Parts so the plow truck will be 95% KM parts but it should last cause it won’t be getting the crap bashed out of it.
    I’m almost done with the plow setup I just have to figure out a body for it and get the motor and esc. I’ll be running a 580kv and a Max5 ESC On 6s SMC Batteries cause I don’t need speed just torque , a 62T spur and 9 or 12T pinion.
  19. Timbo
    Timbo Active Member
    Feb 16, 2017
    32
    6
    Peterborough
    Max5 is a good ESC I run them in my FG conversion and my Baja flux, also ran it on 8s in my 5iveT but was just to heavy for electric hence doing the FG conversion. 6s in heavy truck will pull some amps and load the ESC more than using 8s so keep an eye on temps. Photos when you get chance :)
  20. MGP
    Aug 14, 2017
    50
    2
    I'm running the max5 in my brushless 5T with 8s with no problems with temps. I believe it has to do the quality batteries im running.
    I might go 8s just a lower mah battery I don't need the 9200mah in the plow truck. I might run the SMC 6700mah 8s in it. I will post pics and video when its all done
