Probably not. I think Mike said it's a 1/2" size sockedDo I need to remove the head or something to get to the decompression valve. Mine needs to be tightened bit none of my sockets will fit in between the fins. Rcmax 65cc.
View attachment 60309View attachment 60310
No idea, ask Mike ? can we see the Piston an cyl?Damn??My 3/8 drive socket didn't fit but my 1/4 drive 1/2" did fit. Oh, anyone know the torque spec on the head bolts? Really????
View attachment 60311View attachment 60312
Nah the valve IS needed????
Dam right it is?I know nothing about used 47mm pistons ??
Whenever you pull the pull start. Push in valve, then pull cord. The valve will pop out on it's own.I never heard of a decompression valve on these engines, I know some motor bikes have them to restart the engine once hot as I makes it easier to kick start, and tractors have them for a cold start morning or if your battery is low. When do you ever open it up crucialRC?
Rcmax 65cc??Ah cool must be high comp or big block, would need to be a beast of a motor to have that from factory ?
