Dragon hammer v2 parts
Ghostman112
Anyone know what dbxl and 5t parts fit the dragon hammer v2 I've recently acquired one runs great no problems but I want to stock up on spares
no 5t parts are compatable mate,
but dbxl parts will work, some need modifying,
dbxl clutch bell carrier works,
dbxl split centre diff carrier works but you need to fit the dragon hammer spur cover,
dbxl brake pads and brake covers work,
all dbxl diff parts are the same as long as the crown wheel and pinion are spiral cut gears,
dbxl diff rebuild kits work, all diff internal gears are the same,
dbxl cv rebuild kits work ( both centre driveline and front outers) but the small drums need a very minor amount removing,
dbxl front diff case ( the part that carries the diff( are the same, but needs to be fitted upside down,
dbxl front diff towers are very similar and should fit but not 100% on that,
dbxl spur gears fit, using the aftermarket spurs gives you more gearing options for the dragon hammer,
dbxl clutch bell will work,
there will be some more dbxl parts that will work on the dragon hammer, but its a case of see if they look the same and then risk it when buying,
the ones i listed above will work on the v1 and v2 cos drivelines are basically the same,
i have a v1 dragon hammer,
edit; link to my dragon hammer build thread mate (y), might give you some ideas, you may have to scan through the pages for the oics cos theres a fair bit of banter in there as well :LOL:,
https://www.largescaleforums.com/threads/spents-obr-57-twin-dragon-hammer.26692/
Thanks 😊 at least I know now dragonhammer v2 parts are so hard to find
the parts should become much more available now mate cos fid are on here and just said last week that they launched there new store for the dragon hammer (y)
